Old 02-24-2014, 08:00 PM   #23 (permalink)
star_deceiver
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
I'll post pics like these on facebook...
90% of the time someone will comment "Why do you have it apart?" "Did you break it?" "Don't you let the dealer do that stuff?" "Your transfer case fluid needs changing? Doesn't that last forever?" "Studded winter tires? You have 4wd." "How much did you spend on transmission fluid? But that truck is new." "Motorcycle tires wear out after how many kms?"
Well the engine, transmission, transfer case, and both differentials have different oils that need changing at regular intervals... simple maintenance!
My truck and bikes will run... Because I do the necessary work to keep them in tip top running condition!
And yes, that's what the inside of a GM 8.6" rear diff with G80 looks like... Had they provided a drain plug on the diff cover I wouldn't have had to take it off to change the oil!
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
The Following User Says Thank You to star_deceiver For This Useful Post:
yoyoyoda (03-06-2014)
