Old 07-05-2008, 02:39 PM   #92 (permalink)
whatthe
Power tuner gone eco
whatthe's Avatar
Prudence - '93 BMW 325 i
90 day: 36.64 mpg (US)
Originally Posted by RH77 View Post
For most vehicles, turning the key to the "On" position after cutting the engine will engage electronic controls: ABS, airbags, stability control, signals, etc.
I actually had to perform a full ABS stop while EOC-ing last year. I hadn't touched the brakes, so I had full vac and stopped missing the obstacle without a problem. The ABS motor will cycle the channels more slowly, but the force is still the same. It depends on battery power.
In the TSX, I tried the stability control in a parking lot with snow. It's a bit "muted" -- it acts more slowly, but still does the job. That car doesn't see much EOC time -- heavy steering and a long crank-over.
You can still see a benefit further back. I don't draft trucks, period. The rule is, if you can see the driver's mirrors, you're OK.
RH77
I know the accumulator on my toyota is rated at 14 Volts so under load with just battery, I could see the system being much slower.
I just think it's one of those procedures that people should test on an empty road somewhere with their car to see how it behaves.
1992 - Suzuki Swift GT
