Really confused.
4 the following reason this thread about "water injection" started reading the thread and found the HHO crowd.
I am neither pro or con on HHO just not what I am looking for...............
Water injection aka circa 1975-1980 tech alchol/ water mix and then in vapor form is in fact what I am curious about. This was used in the decade pasts with some results and that is why you can by ebay kits in the 400-500 us dollar range with pump/tank/mister etc.
I am just curious how you tube connect on a 2004 toyota ......the old way was via egr tubes, evap lines with a tee..............
