Originally Posted by XYZ
I also do this often at long lights. But then I wonder while sitting there (sometimes sitting in the cold, without the benefit of having the heater warming me in winter): how much money have I saved in unspent fuel as compared to this recurrent wear on my starter? I've changed the starter on my car twice over many years, and replacing it isn't an easy task. Actually it's a b---h.
Maybe this routine balances out at best. Maybe I am just breaking even. If I'm only breaking even, I ask myself what's the point of doing it?
I completely agree with your point. After a couple of times starting the engine, I realized A) extra starter wear, and B) how much fuel does my 3.7 use to crank over?
What I have started to do, is NOT cut the engine at lights unless I EOC up to the light, or I KNOW how long it will be. Back near my last college, there was a light that went in circles, with 6 angles, and a solid 2.5 minutes if you missed the light. Often, I will bump start my engine before coming to a complete stop to avoid having to crank it over. Either way I will need to start it, but that way I save a bit on the starter.
