Old 02-28-2014, 09:56 PM   #6 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
My Toyota came equipped with 3.73 gears. I don't know how hard it would be to cut down an axle to fit under your Tracker, but there's lots of Toys out there.
Here's a page that lists Toyota axle codes so you know what ratio you're looking at.
Kubota's current 1803 engine is a 1.8l 3-cyl rated at 28hp at 2700rpm. The V2203 is a little older, a 2.2 4-cyl rated at about 48hp, but that's the NA version. I don't think it was available factory turbo, but
The Following User Says Thank You to elhigh For This Useful Post:
Joggernot (03-01-2014)
