Old 03-01-2014, 09:52 AM   #2 (permalink)
oil pan 4
Originally Posted by Big time View Post
If water steam cycles were implemented for higher engine efficiency would the average Joe remember to refill water every day?
I wouldn't see why not.
If sea water could be used in steam systems in cars driven on arid lands could then cars actually prevent or reverse desertification?
No it wont. That much water vapor would be a fart in the wind. I have been to places in africa and the middle east where its very humid all day and night. Just because its desart doesn't mean its dry.
Blowing water in the exhaust to boost turbo power recovery
That wont work. Turbochargers are heat engines.
You use that heat to do work. It can drive a turbine or boil water.
Boiling the water is work, if you boil water before the turbine so much sensible heat will be lost to latent heating of the water the exhaust stream wont have a high enough temperature to expreance much of any temperature drop when it goes accrost the turbine, there for wont be able to do any work.
Turbochargers already boost fuel economy by up to 20% on diesels.
