Old 03-01-2014, 11:02 AM   #12 (permalink)
oil pan 4
I have been there and done that. Stick with a belt driven pump.
I should have kept the belt driven pump, that would have made doing a alt belt removal a lot more possible for 2 reasons. I would be able to take the alt belt off, since there would be 2 belts, with out the water pump a single belt drives everything.
Having a mechanical water pump means there is 5 or 6 amps less electrical draw, running battery power only will last that much longer.
