Old 03-01-2014, 03:25 PM   #7 (permalink)
oil pan 4
[QUOTE=Christ;413214]Turbochargers are /pressure/ engines, not heat engines. If the water evaporates while crossing the face of the turbine, the steam expansion rate creates a higher pressure differential across its face, thus increasing the power by which it can be driven. The heat is completely circumstantial to this [QUOTE]
If this worked why isnt it in use on large turbodiesel power generators, ship engines or gas turbine power plants?
I know some engineers I can pitch this idea to. I already know their first reaction will be to laugh at me.
Not to mention the idea of having liquid water droplets in contact with the turbine is a bad idea. Causing drag, erosion things things you dont want.
