Just ride it like you would a bicycle, if you know what that's like then driving a car will never feel the same again
What you need to do is practice practice practice, at slow speeds of 20-30km/h.
I suggest practicing on a closed street with a small amount of acceleration, possibly without any shoes on.
Then gradually add acceleration to the mix until you learn how to hit the mark spot on every time.
Even the ISS has to accelerate sometime due to drag:
Or install an air brake on the rear of your car and attach it to your floor via spring loaded cable.
Technically its not cheating because you're not using your brakes.
Maybe call it an "air diverting hand" or something.
![](http://i.imgur.com/imx7CNc.jpg)
