I've read on other threads that it's better for the air dam to go from half way/middle of tire to half way/middle of tire. If you have the air dam from outside edge to outside edge the air won't 'wrap' around the side of the car, rater be pushed out at an angle away from the car.
Again, this is what I have read, hopefully Aerohead or somebody more knowledgeable than me will chime in.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
