Old 03-03-2014, 12:39 AM   #1 (permalink)
SpeedyCorky
also races Sportbikes!!!
SpeedyCorky's Avatar
Mo' Mon-nay! - '00 Honda Civic HX
90 day: 52.26 mpg (US)
Carbon Silver - '06 Honda Insight
90 day: 82.2 mpg (US)
2000 Civic HX: Passed CA Smog test with 49state ECU installed in a CA car!
well as the title says folks! and actually, I totally did it by accident!
I was going to install my CA ECU for the test, but forgot!
So story goes I have a 100% California model 2000 Civic HX. the California ECU is different than the 49state ECU in that, the 49state ECU is much easier to get into lean burn - which you know, is pretty key. So I of course had to ditch my CA ECU!
CA ECU: P2N-L32
49state ECU: P2N-A32
So after much research and exploration and a thread or two, I found a 49state ECU, bought that puppy up and installed it. Sure enough, it worked as people had said it would! But I was afraid to run it thru a California Smog test. I just figured I'd swap back in the CA ECU for the test, just to be safe.
Turns out, you can keep your 49state ECU in your car, for a California Smog test
2000 Honda Civic HX with mild aero mods
2006 Honda Insight
MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
