What i did, don't have pictures. 1 large convex mirror from Walmart, a hose clamp bracket. Take off the interior triangle which holds bolts for the side mirror. Wing nut the hose bracket to the existing bolts used to hold the mirror. Wing nut the Mirror to the bracket by drilling a hole in the back.
It works great on the drivers side, but on the passenger side it's poor. Passenger side mirrors should be flat or a little concave like stock. The convex mirror on the passenger side makes everything look to small.
The only problem i have is it blocks the vents on the doors that defrost the windows. I get uneven fog lines on the roll down side windows.
I wouldn't consider tape or glue. Bolting is best. Closing your door will knock the mirrors out of alignment if taped or glue. Suction to the windshield is good if you can find a long enough phone holder device.
I try to be helpful. I'm not an expert.
