Originally Posted by Joggernot
How did you seal the gaps up front? Foam?
Joggernot
Yes I used a strip from front to back between the skirt and rocker panel.
Originally Posted by KrautBurner
have you thought about going with a T56 (Manual 6 speed)?
it's got a double overdrive
would probably make a difference
but with those 3.23 rear gears, you may need to go 75mph to get peak mpg
my 4,000+lb GTO with a 400HP 6.0L (when stock)
was getting 30-32mpg on the highway (if I could keep the speed up about 70-75mph)
and that's with 3.46 gears
now, she gets about 23-24mpg highway
I have considered a T56 but those cost their weight in gold around here, and I have been planning a 6L80 swap with 2.73 or numerically lower ratio rear for a while now anyway.
btw,
your front tires are on backwords?
are those Mich Pilot Sport A/S?
Yes and yes. I swapped them a while back to diagnose a problem pulling to the right and have yet to swap them back.
Fully sequential port fuel injection
406 sbc 350hp @4800 425lb-ft @3600
4L60e trans .70 OD, 3.23:1 rear, 26" dia. tire, 1,600rpm @55, 2,050rpm @70
