Old 03-11-2014, 08:03 PM   #1 (permalink)
sjgrimsley's Avatar
Trans Am - '82 Pontiac Firebird Trans Am
90 day: 20.84 mpg (US)
Explorer - '95 Ford Explorer XLT
90 day: 19.02 mpg (US)
Trans Am build thread
I decided I should start a new thread for any further mods I do on my car instead of posting to my intro thread.
A little background, I typically get 18.5~19 mpg. 20.5-21 mpg if I really, really tried. After sealing up gaps at the front of the car, and extending the front air dam, it's up to 21.7 and 21.5 without too much effort. My next mod was side skirts.
Anyway, I have a couple of pictures to post of the rain gutter side skirts I finished last night.
They started out white, but a can and a half of black plasti-dip fixed that. I also made up an inner pair of skirts to go up to the inside edges of the tires, but I don't have any way to mount those yet.
All told, I have less than $25 in them. When I installed them last night I had about 220 miles on the current tank. After today's commute to work and back there are 265 miles on the tank. Probably will see no difference until I have a full tank with these on here.
Fully sequential port fuel injection
406 sbc 350hp @4800 425lb-ft @3600
4L60e trans .70 OD, 3.23:1 rear, 26" dia. tire, 1,600rpm @55, 2,050rpm @70
Old 03-12-2014, 08:25 AM   #2 (permalink)
Joggernot's Avatar
How did you seal the gaps up front? Foam?
Joggernot
Old 03-12-2014, 01:38 PM   #3 (permalink)
KrautBurner's Avatar
Cavalier of D00M - '05 Pontiac GTO LS2 T56
90 day: 23.2 mpg (US)
The New One - '10 Toyota Prius II
90 day: 51.55 mpg (US)
Chick Magnet - '91 Geo Metro 3cyl/5sp
90 day: 48.07 mpg (US)
have you thought about going with a T56 (Manual 6 speed)?
it's got a double overdrive
would probably make a difference
but with those 3.23 rear gears, you may need to go 75mph to get peak mpg
my 4,000+lb GTO with a 400HP 6.0L (when stock)
was getting 30-32mpg on the highway (if I could keep the speed up about 70-75mph)
and that's with 3.46 gears
now, she gets about 23-24mpg highway
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Old 03-12-2014, 01:47 PM   #4 (permalink)
btw,
your front tires are on backwords?
are those Mich Pilot Sport A/S?
Old 03-12-2014, 07:22 PM   #5 (permalink)
sjgrimsley's Avatar
Joggernot
Yes I used a strip from front to back between the skirt and rocker panel.
I have considered a T56 but those cost their weight in gold around here, and I have been planning a 6L80 swap with 2.73 or numerically lower ratio rear for a while now anyway.
btw,
Yes and yes. I swapped them a while back to diagnose a problem pulling to the right and have yet to swap them back.
Old 03-13-2014, 04:09 AM   #6 (permalink)
If the l480 and l680 use the same first gear then using a 2.73 rear is going to be slugish.
What kind of wheels are those?
And are they lighter than the factory wheels?
The factory iroc alloy wheels weigh 22lb.
Old 03-13-2014, 01:55 PM   #7 (permalink)
sjgrimsley's Avatar
The 4L60 has a 3.06:1 1st gear and the 6L80 has a 4.03:1 1st gear. For a reference, the C6 08+ Corvettes with the 6L80 come with a standard 2.56:1 ratio or an optional 2.73:1 'performance' ratio.
With the torque this 406 already makes, I am tempted to try the 2.56:1 rear with the current 4L60 trans.
And these are C5 Z06 replicas 17"x8.5" front, 18"x9.5" rear. I have them to clear the future brake upgrade. The factory wheels won't clear the front rotors I'm looking at getting.
Old 03-13-2014, 06:57 PM   #8 (permalink)
Do you think front 17 inch vette wheels will fit all 4 corners of a 3rd gen?
Old 03-14-2014, 12:28 AM   #9 (permalink)
sjgrimsley's Avatar
They will for sure. But this a dual purpose car of sorts haha
Call me crazy but this is sort of my quest to build the poor man's Z06 which is a 427 (7.0L) rated 505 hp and returns 28 mpg at 75 mph. If it can do it, I feel I should be able to get close. It has 18" front and 19" rear and they are wider.
I'm sure it's considerably less frontal area than my car, and I know it sits lower, but I don't think it's THAT much of a difference. But I could be wrong. Lol
Old 03-14-2014, 04:19 AM   #10 (permalink)
The thing is the last body style of hyundai sonata the v6 has very simular weight, frontal square footage and Cd as a 3rd gen. The hyunda gets up to 8mpg better than the old V8 80s car.
So its possible for car of that mass and aero profile to get mpgs in the high 20s. The difference is all engine, engine management and gearing.
mcrews (01-11-2016)
