Old 03-14-2014, 08:42 AM   #3 (permalink)
justme1969
justme1969's Avatar
Well sir that one can go either way on ya. is there a place where all the honda kids go in your area? That will probbably be good route or anywhere that a guarantee is valid and without doubts. You dont really explain if your doing the install but I sorta feel like you arent. It has always been the case that I can buy a remanufactured engine with warrenty for less than any shop will build it for, regardless of if they can even build it better. I suggest you shop around some because some of the hot dogg civic power tricks also help mpg when used responsibly.
