Old 03-14-2014, 04:41 PM   #18 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by RustyLugNut View Post
Again, the temperature of a gas is a measure of how much each molecule is vibrating and moving and impacting a barrier resulting in pressure.
I think you just put this to bed, right here (again).
A turbo is a pressure based engine. Heat is, in essence, a form of pressure, in that the molecules react more creating a larger pressure on the surroundings (e.g. turbine). Calling it a heat engine is only a part of the puzzle, it's not the wrong answer, it's just that it's only a part of the right one.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
