I don't.recall exactly, it was so long ago. Based on my picture, I must have jacked up one side, place a jack stand there. Moved the jack to the other side, jacked it up. This made the rear bumper high enough to slide the jack stand under the rear tow hook.
Edit: I forgot, your car is the si vtec model. I'm not used to seeing del sold in that trim, so I just assumed dual cams in a del sol is an engine swap.
