03-15-2014, 09:30 AM
#63 (permalink)
The lower block was a no-tools installation/removal part.
The part was shaped to fit snugly in the lower opening. I attached bungee cords to the backside of the block and ran the cords straight back through the grille slats, then turned a 90 degree corner, upward to the rad support crossmember where I hooked them on.
That said, I never had to remove the part for cooling reasons.
