there is no reason to test a K & N
Originally Posted by Cobb
Ok.
Shame they didnt test a kn.
there is no reason to test the K & N
other testing from different sources was performed with various filters
and
with no filter at all
with and without
up to a 50% restriction imposed by a custom cut chunk of cardboard to cover 50% of the filter surface added for good measure
so unless the K & N filter has a negative resistance to flow
ie BOOST
it can not make an improvement over no filter at all , just an empty air filter housing
which resulted in zero FE change
so
bottom line
any test result especially from K & N that claims an FE improvement using a K & N air filter is
BOGUS
and belongs ..... right here
in the poop pile
Reason: false
