Old 03-17-2014, 11:38 AM   #31 (permalink)
RustyLugNut
I agree.
Originally Posted by P-hack View Post
Yes, but the turbine in a turbo isn't a peltier junction or a stirling engine. Preserving the exhaust heat is basic PV=NRT stuff, decrease T and P goes down. The IC is a gas generator, and waste heat is entropy's way of saying screw y'all (unless it is cold outside, then maybe you have a use for it).
What is the point of your discussion?
Lost heat before the turbo results in less pressure which results in less mass moved through the turbine.
