Old 03-17-2014, 11:38 AM   #31 (permalink)
I agree.
Originally Posted by P-hack View Post
Yes, but the turbine in a turbo isn't a peltier junction or a stirling engine. Preserving the exhaust heat is basic PV=NRT stuff, decrease T and P goes down. The IC is a gas generator, and waste heat is entropy's way of saying screw y'all (unless it is cold outside, then maybe you have a use for it).
What is the point of your discussion?
Lost heat before the turbo results in less pressure which results in less mass moved through the turbine.
Old 03-17-2014, 11:57 AM   #32 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Point? I dunno, you tell me.
Anyway I think it is worth distinguishing between gas and diesels too. Turbo's seem to be an efficiency penalty on gas engines, while an efficiency boost on diesels.
lower peak bsfc for spark normally aspirated (page 874, fig 15-38)
lower peak bsfc for diesel turbo (page 876, fig 15-40) (plus much better power/weight at improved bsfc)
http://www.rmcet.com/lib/E-Books/Mec...ndamentals.pdf
The Following User Says Thank You to P-hack For This Useful Post:
RustyLugNut (03-17-2014)
Old 03-17-2014, 12:25 PM   #33 (permalink)
The original post was for steam engines . . .
. . . which was extended to the idea of a partial steam implementation in the exhaust driven turbo charger.
You are now extending the discussion to another area. Maybe a new thread is in order.
But, your reference is interesting in that many people assume that the increased efficiency gained by a diesel with a turbo charger applied can also be found by applying a turbo charger to a gasoline engine ignoring the differences in combustion operation. That is not the case.
Thank you for the link by the way. Heywood is a classic.
The Following User Says Thank You to RustyLugNut For This Useful Post:
Cobb (03-17-2014)
