Old 03-17-2014, 06:01 PM   #65 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
yah, the site is goofy, they compute the wheel speed @100kph for the stock tire, then use that to compare to the new tire. But at 62.14 mph indicated, you will actually be going 65.14mph with the 185/60r15s. If you want even taller "gearing" then go with a 185/70r15, though the extra width probably isn't going to be helpful for mpg.
