Old 03-17-2014, 05:09 PM   #61 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
the speedo/odo read wheel rpm. If you make the tires larger, the car will go faster for a given wheel rpm, but the speedo won't know about it so it reads less than actual. They are calibrated for a certain tire size.
Old 03-17-2014, 05:25 PM   #62 (permalink)
Micromachine - '94 Honda Civic DX hatchback
According to 1010tires the speed variance will be 4.61% more with bigger wheels, the speedometer will read 65.14MPH with 15'' versus 62.14MPH with 13'' wheels, that is read more than actual. honestly I am confused here.
Old 03-17-2014, 05:35 PM   #63 (permalink)
P-hack's Avatar
there are several figures, tire width/aspect ratio and diameter. they all play into revs/mile.
I put in my 195/60r15 and compared it to taller (via 70% of treadwidth) 195/70/r15 it gave me 62.14mph stock vs 66.08 mph for the larger tire. which seems about right.
What three values did you use for each tire?
Old 03-17-2014, 05:50 PM   #64 (permalink)
175/70R13 stock vs 185/60R15 current.
Old 03-17-2014, 06:01 PM   #65 (permalink)
P-hack's Avatar
yah, the site is goofy, they compute the wheel speed @100kph for the stock tire, then use that to compare to the new tire. But at 62.14 mph indicated, you will actually be going 65.14mph with the 185/60r15s. If you want even taller "gearing" then go with a 185/70r15, though the extra width probably isn't going to be helpful for mpg.
Old 03-17-2014, 06:11 PM   #66 (permalink)
I am happy with the current tires, great response at take off. The main goal at the moment is to increase the FE, I am still in the learning process.
Old 03-17-2014, 06:24 PM   #67 (permalink)
P-hack's Avatar
Generally speaking, these are conflicting goals.
The Following User Says Thank You to P-hack For This Useful Post:
Fat Charlie (03-18-2014)
Old 03-17-2014, 06:32 PM   #68 (permalink)
Sorry I didn't explain well. I am not talking about speed, just want to say that they don't put much strain on the transaxle/clutch as taller wheels might do. I try to do modifications that will not harm other components in the long run.
Old 03-17-2014, 07:34 PM   #69 (permalink)
P-hack's Avatar
Well, I don't want to propagate the notion that taller gearing equates to premature failure. Do you have specific concerns, and data behind them? There's a lot of variables in play here, such as lower rpm, which is less stress on a piston engine. I've never had a problem with gearing up, driveability or maintenance.
Old 03-17-2014, 07:47 PM   #70 (permalink)
The specific concern I have is wearing the clutch faster, I have no data or evidence to prove that, just my opinion.
