Originally Posted by Ironside
Thanks for the input P-hack, that would be perfect for a permanent fixture. I don't know the optimim size or location, so I thought I could experiment with a stick on plastic strip.
Does anyone know what Theo uses?
Try clear plastic L shaped corner piece used to protect corners of sheetrock walls in houses. Comes in 8' lengths, straight but somewhat flexible.
Very cheap at Home Depot or Lowes. Stick on with two-sided carpet tape or sticky foam tape. You could add yarn tufts, record the effects with GoPro camera.
