Originally Posted by darcane
Not too shabby.
Like most manufacturers, Honda turns on the AC when you move to defrost and you can't turn it off. Unlike most manufacturers, Honda allows you to change this behavior. With a simple procedure you can change it to manually toggle the AC:
DIY: Shutting of A/C during defrost
It will still turn on AC when you select Defrost, but just push the button and it will turn back off.
Wow, that is strange. Thanks for the tip!
