Old 03-22-2014, 10:57 AM   #25 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Balto, Some questions and considerations. How do you know the temperature is reaching 235? From your garage entry you have an added temperature gauge. Have you verified that against another method of measurement? If your gauge is electronic it only reports the information received from the sender. Bad sender? If you temperature is climbing that high at a steady 45 MPH you need to be looking at some other issue other than just fans.
As recommended in other threads you could try pulsing your heater or a continuous partial heat setting to reduce the temperature until you can get it repaired. Grill bock removed?
