Old 03-22-2014, 11:12 AM   #26 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by nemo View Post
Balto, Some questions and considerations. How do you know the temperature is reaching 235? From your garage entry you have an added temperature gauge. Have you verified that against another method of measurement? If your gauge is electronic it only reports the information received from the sender. Bad sender? If you temperature is climbing that high at a steady 45 MPH you need to be looking at some other issue other than just fans.
As recommended in other threads you could try pulsing your heater or a continuous partial heat setting to reduce the temperature until you can get it repaired. Grill bock removed?
Yes I have an aftermarket gauge, I don't have any other way of knowing other then that sensor. I'll try it at 45MPH and see if it surpasses 210. Yes my grill block is removed. I hope my gauge isn't broken it costed me a lot to have the damn thing put in.
