Originally Posted by ksa8907
Yes, but it was also mentioned that they do not turn on when the temps rise, only with the a/c on do they come on. That is what I am suggesting he fix. Thank you
I agree. Obviously since both fans *do* run when the A/C is on, the problem is not with the fans themselves. If I recall correctly, on Toyotas the primary fan is used for normal cooling and the secondary fan also runs (meaning both fans will run) when the A/C is used. So I'm asking why the primary fan isn't being activated when the A/C is not being used.
