Watch the coolant levels religiously for at least a week. Both the radiator itself and the recovery bottle. If it's working right the radiator will suck coolant out of the reservoir when it cools down, so check it right when you turn it off and again when it's cold. Once that level is consistent in both cold and hot states mark the recovery bottle with a magic marker. Keep an eye on it for a while.
If you aren't loosing any coolant your are lucky and all is well.
regards
Mech
