Old 03-25-2014, 06:03 PM   #3 (permalink)
AlexVLZ
Hi,
What do you mean with engine oil consumption in relation to a thinner oil?
I was thinking about picking up this ELF 5w30 Evolution that they advertise that reduces "increases up to 8% fuel consumption" which I know is pure marketing, but at least it mentions it, others don't --so there might be some truth there. Second option is this 5w40.
thanks
Alex
You're trying for two opposite goals: you want a lower weight oil for fuel efficiency, and probably a higher weight oil to reduce oil consumption. The main job of oil is to lube the engine, so I'd worry more about consumption- it doesn't matter what slight improvement you get in gas mileage you get if you're always adding oil.
