Old 03-25-2014, 10:46 PM   #14 (permalink)
cRiPpLe_rOoStEr
I also considered kinda odd that GM went with the V8 instead of a V6 in the hybrid layout. Well, the electric motor would be supposed to overcome the lower power either in highway or higher load conditions...
Originally Posted by jeff88 View Post
This is just a half joke, take it with a grain of salt. You could put a turbo, so in v4 mode it will have more power and stay out of v8 mode. Don't know if it would use less gas than v8 n/a mode, but it's something you might want to look into.
Turbocharging an engine with Atkinson-effect cams, like it's usual in hybrids, is harder due to some backpressure at the intake manifold, but a supercharger may be useful. Until mid-50s it was not unusual to use superchargers in industrial and marine engines which got a longer intake valve timing, as a measure to overcome the lower dynamic compression issue.
