150ma collector emitter max on those optos, sounds like your "fuel" meter will work as-is, but the temp meter current is a bit high, but sounds like it needs some more resistance anyway (probably the original sensor wasn't 0 ohms at max temp, 12v+pot to determine FSD ohms). You are making it look easy
