Originally Posted by California98Civic
If the engine is off, it is because the injectors are not firing. But i am not sure i completely understand the question.
I turned the engine off with the key, switched the key right back on, and used a bump to restart the engine. Even though the key was back on, the ultragauge did not show any mpg information while engine off coasting, and I question the results for that reason.
