Old 03-26-2014, 10:50 PM   #9 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
What other differences are there in the wheels and what tires will be on each? Width of tire and weight of tire counts. Diameter of wheel counts. Eight pounds per wheel can be multiplied by 2 or even 4, depending. That's because it is rotational mass. So your're looking possible at a 64-128 pound *effect* from lighter wheels. And as long as long as you don't cancel that out with heavier, wider, stickier tires, you could see a modest benefit. BUT... if you compou d the benefit by getting same weight or lighter tires, narrower, and of the low rolling reststance grade... even more benefit.... check tirerack.com extensively.
101Volts (03-27-2014)
