Old 03-27-2014, 01:45 AM   #64 (permalink)
cRiPpLe_rOoStEr
There is potential in some alternate fueling and engine management schemes but IMHO you need to walk before you can run. There is a lot of variation in a vehicle's operating environment and I think the learning curve for much of this sort of thing is too steep. I'd use a stationary engine as the mule, and make it perform useful work like space heating and power generation, or even pumping water or some such.
Gotta have to second that. Actually, if you could find either a 2-stroke spark-ignited engine or a 4-stroke Diesel, they seem to be the best options for a "multifuel" development. IIRC Evinrude once developed a "multifuel" outboard motor which could also run on Jet-A1 and JP-8 (altough I'm not sure about how it would fare with heavier stuff such as Diesel fuel or wood tar). Lotus also have been working in a 2-stroke "omnivore" engine...
You may also be interested in a system currently under development by Westport which uses a glowplug to ignite CNG in a direct-injection Diesel engine. If you could apply that as a replacement for the average spark-plug in a random 2-stroke engine, that would be possibly the best setup as far as "multifuel" ability goes, with a quicker cold-start than the old hot-bulb engines...
