Old 03-27-2014, 02:43 AM   #11 (permalink)
Istas
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
Rim shape will make a big difference too. If the steel rims are mostly smooth, and the alloys have big gaping holes and/or flat surfaces spinning against the airflow, that could (probably would, over ~40mph) more than offset any gain you'd get from lighter weight.
(Whichever rims accept full hubcaps can give you the advantage of being able to attach as smooth a surface as you like.)
The Following User Says Thank You to Istas For This Useful Post:
101Volts (03-27-2014)
