Old 03-27-2014, 02:43 AM   #11 (permalink)
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
Rim shape will make a big difference too. If the steel rims are mostly smooth, and the alloys have big gaping holes and/or flat surfaces spinning against the airflow, that could (probably would, over ~40mph) more than offset any gain you'd get from lighter weight.
(Whichever rims accept full hubcaps can give you the advantage of being able to attach as smooth a surface as you like.)
The Following User Says Thank You to Istas For This Useful Post:
101Volts (03-27-2014)
Old 03-27-2014, 04:10 AM   #12 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Depending on your driving conditions it won't add up to much improvement. Acceleration can be improved for stop and go driving. On the highway at steady speed there isn't much difference. The general trend from automakers has been towards aerodynamics rather than weight. I've cited Honda many times on this issue. The VX and HX of the 1990's were equipped with super light wheels. As you moved into the 2000's the first gen Insight and Civic Hybrid had more aerodynamic wheels instead of focusing on just weight. There are a lot of threads on Ecomodder about MPG improvements from wheel covers.
The ideal solution would be a lightweight wheel with a wheel cover. But if you have to spend a significant amount of $$$ on the light wheels, it would take a long time to return any savings vs. just adding wheel covers to your steel wheels.
1998 Honda Civic HX - My Project Thread
The Following User Says Thank You to cbaber For This Useful Post:
Old 03-27-2014, 04:42 AM   #13 (permalink)
Grogu - '12 Toyota Tacoma Base regular cab 4x4
90 day: 23.3 mpg (US)
I was kinda leaning towards the vintage et or ansen slots. They don't seem too aerodynamic though. I guess my steelies aren't too good either.
The Following User Says Thank You to craveman85 For This Useful Post:
Old 03-27-2014, 11:24 AM   #14 (permalink)
Any chance you could get good LLR tires and put snow chains on them when needed?
Old 03-27-2014, 12:04 PM   #15 (permalink)
No I had some big long trail ta a long time ago on another truck. They're considered low resistance for a truck tire but I had many problems with them. My typical use involves too many boat ramps, dirt roads, fields with clay in them, wet grass... Tires stay. I do have a friend with the exact same truck but an equally aggressive all terrain tire and his gets 2 lessmpg than mine did. The rubber compound is harder on ccommercial traction tires which helps quite a bit.
Old 03-27-2014, 01:45 PM   #16 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Less rotation mass is always a good thing when it comes to acceleration, braking, and MPG. You should see very mild gains in city driving, though highway is unlikely to offer much. I can tell a difference between my 15" light-weight aluminum wheels VS 14" steel wheels in terms of off-the-line acceleration with similar tires. Though, I had a friend who used 17" big ol heavy aluminum wheels (all show) and, as an experiment, swapped my wheels. He noticed a HUGE difference in the get-up-and-go!
Though, another thing to keep in mind: You can't simply "snap on" wheel covers on most aluminum wheels. My Rota Slipstreams are gonna take some real custom work to get them aerodynamically sound. There are a lot of easy snap-on options for steelies.
Old 03-27-2014, 04:28 PM   #17 (permalink)
If it can improve my acceleration then it's definitely worth it for me. My daily commute of 70 miles maybe has 5-7 miles of level or nearly level ground at most. The hills kill my mpg the most right now.
