Old 03-29-2014, 12:19 PM   #2 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
welcome fellow Subaru Owner!
Yes, p&g is typically more efficient than steady state cruising. The only time where it does not help is if the "glide" portion is too short.
The gauge says it only uses .3 gph at idle and actually for a few secs of the coast it reads 0 gph.
Very astute observation. I've noticed my 2013 wrx Sti does the same thing and I think I have found a way to exploit this. I've done some experimenting.
http://ecomodder.com/forum/showthrea...ile-28507.html
It appears that when you step off the throttle, the ecu cuts fuel to the fuel injectors. Therefore, while I am "gliding" during the p&g, if I gently tap the throttle, the ecu will think "off throttle...cut fuel....off throttle...cut fuel...off throttle cut fuel," therefore, I can essentially coast while using very very very minimal gas. My testing shows that I use approximately 78% less gas by "blipping" the throttle vs. straight neutral coasting.
You should try this technique and see if your torque app shows any improvement in mpg during your p&g.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
