Nice work Cobb! What did you use for the 'can'? I've researched doing this mod, but can't seem to find any definite answer: is it advisable to re-use the oil?
Is that the stock battery location or did you move it there?
Since you mentioned it in the video, can you talk about the noodle mod? I imagine it's for insulation, but what are the benefits?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
