65% confirmed? Voltage meter
Hooked up my voltage meter to an injector. Setting a baseline
Idle: 14.25v
Accelerating: voltage drops (11v-13v)
DFCO in gear: 14.36v (steady)
14.36v is my assumption that injectors are not spitting fuel because we all agree that DFCO-in-gear shuts off the fuel injectors
If I do my neutral-throttle-blip while coasting: voltage fluctuates between 13.5v, 14.36v, and 14.25v. Pretty much all voltage values show (as measured above). Therefore, my assumption is that while im on the throttle (13.5v), I step off throttle to shift to neutral (14.36v injectors shut off), rpms drop to idle (14.25v). Then as I continue to throttle blip, voltages fluctuate between 13.5v and 14.25v…then every once in a while 14.36v will flash up.
I’m sure my voltage reader refresh rate is too slow. Therefore, I slowed down my throttle blip. I drove up to 40mph, shifted into neutral, started coasting, then I rose revs up to 2000rpm and held the throttle so that the volts read a steady 13.25v. Then I released the throttle, meter shows 14.36v, then down to 14.25v (idle).
I did it again…initiated the coast….held the throttle at 2000rpm…meter shows 13.25v steady…then I step off throttle, meter shows 14.36v, then down to 14.25v (idle)
Thoughts? Comments? Suggestions?
I’m getting ready to hook up the mpguino soon. Just gotta find a 12v source….or buy extra wire to reach the car batter
