Originally Posted by beatr911
From the NC700 forum... "Putting the DCT rear sprocket on the X would drop the teeth from 43 to 39. At 70MPH, this would reduce engine RPM from 3522 to 3194." Don't know how significantly this will affect mileage but it will help the very low first gear you mention. I'd do it if the chain is still in great shape, if not wait like you indicated.
I'd surely surely do it if I had an NC700!
A front sprocket replacement (14->15 teeth) on my girlfriend's Hyosung GV250 improved FE by about the amount of difference between the two setups. I'm still surprised, I wouldn't have thought it would help this much.
