How VW addressed TC lockup
I owned a 1968 VW bug that had "automatic stick shift"
As near as I could tell, it was a manual transmission that was mated
to a TC. There was no manual clutch. I shifted the transmission
just like a manual transmission. The knob on the stick shift had a sensitive
switch that would make contact whenever you touched the knob.
This switch controlled the TC lockup solenoid.
It was a good and simple set up that always worked perfectly.
I hope you can use this info.
