Old 04-06-2014, 12:47 PM   #24 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I used one of the Haas current sensors that Paul's open revolt uses in my BMS, but it wasn't as accurate as I'd like it to be.
Did you include the capacitors that are in the datasheet? Omitting them would certainly cause erratic readings.
The 47nF cap between 0V and 5V isn't necessary because the arduino already has a much larger cap between its 5V and ground. But the 4.7nF cap between output and 0V will no doubt smooth out signal irregularities.
