Old 04-06-2014, 04:03 PM   #7 (permalink)
jamesqf
Originally Posted by Big time View Post
If so, then it looks like the 70s oil crisis was "solved" wrong
Instead of warmongering the middle East to TRY to get cheap oil...
You do know that the '70s oil embargo really wasn't about oil at all: oil was just a weapon used in a dispute that was (and still is) fundamentally about religious and ethnic differences. (That much is history: further comment would descend into politics, so I'll refrain.)
To the original point, EFI systems are much simpler than carburetors, especially the ones used on automobiles from the mid-50s on. If you've ever taken one apart, you'll have seen that they're a maze of passages filled with jets, valves, springs and such, which all have to be sized right - and clean - to function properly. Then you have to painstakingly adjust things by hand to get mixture & idle speed correct, except that 'correct' only holds for a particular elevation & temperature range. And don't even get me started on trying to balance multiple carbs...
EFI is brilliantly simple by contrast: a simple pump squirts a measured amount of fuel into the cylinder, while a sensor measures the exhaust and uses a feedback loop to correct the amount.
