There was a report on CNN about the pitfalls of hypermiling. The woman who was advising against it has probably 1.) never been financially strapped enough to care & b.) has never been in the car with a hypermiler at the wheel.
EOC can be dangerous if you don't know the limitations of your vehicle - which is why it is always advisable to test EOCing on a flat surface away from traffic before you do it on a main road. The most egregious part of the whole segment was not only did they advise against EOC, but they also advised against neutral coasting! They cited that you "lose control of the car". How so? Yes, you do gain speed quicker, but as the driver it is incumbent of you to slow down when you gain too much speed anyway! This fact is independent of whether or not you're coasting in N or D.
argh. getting off the soapbox now.
