Old 04-12-2014, 05:22 PM   #837 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Firmware only change?
Originally Posted by MPaulHolmes View Post
You can use an inverter for a car as an inverter on your house. You just need to filter the 3 sine waves. Well, thats if you want 3 phase power. Just a software modification will turn it into split phase 240vac that all houses have.
This sounds a bit big for a firmware only change!
A Split-phase 240VAC portable (as in truck) supply that can run my shop tools locally at another EV that is broken ... or charge up an EV really quickly .. or run a 3 phase welder (that I can pick up cheap surplus) anywhere ... sounds great ... next year ... since there is only so much time!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (04-12-2014)
