Old 04-15-2014, 01:09 AM   #9 (permalink)
Goldenstate
Heilopower
Platinum Ghost - '14 Ford Fusion SE
90 day: 33.44 mpg (US)
Just installed some new LRR Bridgestone Dueler H/T silica rubber blend tires. With 44 PSI of air, I have seen higher readings on my Scangauge that I ever did with the former high dollar Michlien LTX tires inflated to 37.5 PSI which is over the 35 PSI max they were rated for.
At the same time I have been experiencing some engine service light problems which have been difficult to resolve. Just last week the MAF sensor was found to be bad and was replaced. The Throttle Position Sensor was then found to be in failure mode and was replaced this evening. Tomorrow will see if the engine is working correctly for the first time in several years. No telling what sort of mileage will be seen on the Scanguage during the next mileage testing.
