Old 04-16-2014, 04:24 PM   #2 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Welcome!
I believe there are several on this forum that have modified their mkiv's, both Jetta and Golf. In my case, I've done the grill block and some under-body coverings:
Grill block:
Front under-body (this is the bottom of the front bumper, which I removed to put the coroplast on):
This combines with an engine skid-plate (mine is an OEM steel version, but there are also aluminum ones as well as the OEM plastic under-engine cover)
Rear under-body coverings (closes up the rear bumper "parachute"):
Helga is also lowered by about 1" so that the tires are less exposed.
Would be interesting to see your grill covers.
The Following User Says Thank You to NachtRitter For This Useful Post:
aerohead (04-16-2014)
