Welded in 50 tabs today in 4 hours working with #3 brother. Should be enough to hold the floor, sides, engine harness, radiator, and fuel tank in place. I use speed nuts 6MM with phillips head 6 MM screws. That way I can use one screwdriver to remove just about everything. In other places, Ill drill and tap 10-32 holes in the frame and use countersunk flush face hex drive screws.
Sendler, now it's time to paint the frame which I plan on starting tomorrow (Friday) if my back calms down from today. Then the floor panels can go in permanently with the screws and adhesive sealer.
regards
Mech
