Originally Posted by MetroMPG
Also: are you also manually calculating your MPG on your fuel receipts? Because the UG isn't entirely accurate on a lean-burn engine.
At the moment yes I'm using just gas pump math. I know it's not the most accurate, but I'm doing what I can to help by always using the same fuel pump. The UltraGauge is only showing my consumption in the 40-45mpg range right now. An MPGuino may come down the road for the accuracy.
